Block myself
Hi everyone!
I have MikroTik RouterBoard 450 and I block myself by firewall. On this router there is no serial port, how can I reach the router without doing reset?
Thank you.
Assuming its a 700 series router?There is a way to reset it but first try the following
if you have two routers available plug it into the other and log into one router which you can get into,using /ip neighbors use the mac telnet feature
Just put ethernet cable in another port. And enter by MAC.
Thank you! That’s help :slight_smile:
