Block one IP dossnt seem to work
I have the following filter but it doesnt seem to work? What did I do wrong? I am trying to block the one IP from the internet
chain=input action=drop src-address=10.215.81.105 log=yes log-prefix=""
What ealse have you got in your firewall?
All you are doing is blocking that IP to the router and not the internet and without context of the other rules actually almost meaningless.
Since this is a basic fact you are not aware of, I have to 100% agree with the previous poster in that we need to see your config (and most likely a mess of firewall rules LOL).
/export hide-sensitive file=yourconfigmar14
Yes I just left the automated filters in there when I started it.
Here is the list. Sorry I am new at this!
[mark@MikroTik] > /ip firewall filter print
 0  D ;;; special dummy rule to show fasttrack counters
      chain=forward action=passthrough
 1    ;;; defconf: accept established,related,untracked
      chain=input action=accept connection-state=established,related,untracked
 2    ;;; defconf: drop invalid
      chain=input action=drop connection-state=invalid
 3    ;;; defconf: accept ICMP
      chain=input action=accept protocol=icmp
 4    ;;; defconf: drop all not coming from LAN
      chain=input action=drop in-interface-list=!LAN
 5    ;;; defconf: accept in ipsec policy
      chain=forward action=accept ipsec-policy=in,ipsec
 6    ;;; defconf: accept out ipsec policy
      chain=forward action=accept ipsec-policy=out,ipsec
 7    ;;; defconf: fasttrack
      chain=forward action=fasttrack-connection connection-state=established,related
 8    ;;; defconf: accept established,related, untracked
      chain=forward action=accept connection-state=established,related,untracked
 9    ;;; defconf: drop invalid
      chain=forward action=drop connection-state=invalid
10    ;;; defconf:  drop all from WAN not DSTNATed
      chain=forward action=drop connection-state=new connection-nat-state=!dstnat in-interface-list=WAN
11    chain=input action=drop src-address=10.215.81.105 log=yes log-prefix=""
Address in your FW rule (10.215.81.105) is not a proper internet address. And even if it was, you’re blocking communication between that particular host and router (chain=input … and that particular direction of connection establishment - src-address) … which might be already blocked by rule number 4 (if that’s indeed internet host). If you mean to block communication between LAN hosts and the incriminated host, you should hace similar rule, but with chain=forward and dst-address set to the particular IP (the other direction is already covered by rule #10).
slightly unrelated question: I’ve placed a log on car’s roof … why doesn’t it make car rolling uphill?
I am trying to block the one IP from accessing the internet. 10.215.81.105 is the internal workstation I want to block
So only change the chain from input to forward. To fine-tune the rule you might want to add out-interface-list=WAN
Unrelated: it was aactually a wheel on the car roof failing to make car rolling uphill …
Thank you the forward was all that was needed.
I appreciate everyones help!
How does the wheel on a roof gain traction in air, unless the car was upside down LOL.
