Block openVPN failed logins
Dear Community!
It is possible to somehow block IP addresses when they failed to login through openVPN after X times?
I can see in the log that sometimes from random IP address they try to connect through openVPN.
The only problem is that from the log I can only see that a ‘TCP connection estabilished’ and nothing indicates that this is a failed attempt. But I know it is, because I can’t recognize this IP address, and also if I try to login, there are several other lines in the log when it binds the connection to an interface, etc…
I saw that there are scripts for IPSec tunnels, but I couldn’t find one for openVPN. Can someone help me?
Thanks!
Hi, finally found any solution?
We have the same problem.
Thank you.
There are scripts in the forum that make an address list with log entries and you can then drop that address list. so the possibilities are endless.
