Block outgoing ports on a VLAN
I would like to block certain outgoing ports on a specific VLAN. The best would be to block all of them and then allow exceptions.
How to do that?
P.
Try to ensure that the “use IP firewall” is checked in the bridge config, if you are attaching the VLAN to the bridge.
Otherwise you just add a firewall rule with chain “forward” and in-interface “VLANxxx” with either “accept” or “drop”.
Thats it!
