Block Pihole webgui
Hello!
I have an IoT-VLAN that I want to isolate from all my another VLANs but not internet. It works well except for Pihhole gui (10.10.30.2) which is also the dns. How should I write the rule to block even the http. Tried tcp port 80 both forward and input.
add action=accept chain=input comment="defconf: accept established,related,untracked" connection-state=\
add action=drop chain=input comment="Isolate IoT-vlan" dst-address-list=lan-without-iot-vlan src-address-list=\
    iot-vlan
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=drop chain=forward comment="Isolate IoT-vlan" dst-address-list=lan-without-iot-vlan src-address-list=\
    iot-vlan
add action=fasttrack-connection chain=forward comment="defconf: fasttrack" connection-state=established,related \
    disabled=yes
add action=accept chain=forward comment="defconf: accept established,related,untracked" connection-state=\
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat \
Input is for access to the router, forward is for access all other devices.
I prefer to block everything (as last rule in both input and forward chains) and from there add accept rules for everything you want to allow access to. This way you are complete aware of what your are allowing on your network. But be aware that by this approach you could loose access to the router.
I assume that IoT only should have access to port 53 (TCP& UDP) on the PiHole?
Thanks!
It does not seem to work with just dns. mikrotik gui 10.10.30.1 gets blocked but not 10.10.30.2
add action=accept chain=input comment="Accept mikrotik-gui from admin-vlan" dst-address=10.10.60.1 src-address=\
    10.10.60.0/24
add action=accept chain=input dst-address=10.10.30.2 dst-port=53 protocol=udp src-address=10.10.30.0/24
add action=accept chain=input dst-address=10.10.30.2 dst-port=53 protocol=tcp src-address=10.10.30.0/24
add action=drop chain=input comment="defconf: drop all not coming from LAN" disabled=yes in-interface-list=!LAN
    disabled=yes
