i have a router board 433 and configured hot spot in it, and i know how to block sites using IP.
but i configured hotspot in it, so
my question is how to block some sites for a user name?
There are third party website blocker which will allow you to block certain sites by URL or keywords, you just need to add the unwanted sites to the blacklist abd it is password protected.
thank you for your reply..
can you explain how i can do that???
I’m always when try to block site I’m using this way:
IP-Web Proxy-Acces-Add-then putting the website that i want to block
but when i use this way its blocke the website to all the subnet and i don’t want to do that,
i just want to block sites to a user name.
For blocking certain websites, you can edit the Hosts File, and it goes this way
what you mean (host file)???
Im talking about hotspot that make user name+ password to each user for login
