block skype
How can I block skype ang online game on mikrotik
you can not block skype without accidentaly blocking something else too.
what kind of online game ?
COUNTER STRIKE
Block Skype Successfully see my blog.
http://virtualitsupport.wordpress.com/2013/12/09/how-to-block-skype-traffic-in-mikrotik/
the link does not function
Counter strike uses TCP prot 27015 by default. But at some palces, CS admins uses different port, You can monitor its usage by TORCH tool too.
To block the default port of CS, use the following code …
add chain=input action=drop dst-port=27015 protocol=tcp
add chain=forward action=drop dst-port=27015 protocol=tcp
As normis said, Blocking Skype 100% without blocking something else is a bit difficult in long terms. You have to do some extensive monitoring in order to block the right skype hosts. SKYPE is using whole block of IP addresses from various ranges. Using Wireshark & some digging I found following pools which skype is using for its various functions.BUT do remember that with new updates/ver more hosts can be added. for this purpose you can use Catch Skype Script on mikrotik to detect new addresses and add them to the list.
Also it is possible that some valid/legitimate sites may get blocked with this approach, just find the right ip address of the particular site, and allow it before the deny rule.
Use following code and then try to connect to SKYPE and watch the results. This is purely Hit & Trial method , try it and post your comments or if you have some better way to block SKYPE do let me know.SKYPE have different server’s for different regions, so probably these destinations may not work for you, but at least they are working in Pakistan.
Regard’s
Syed Jahanzaib
/ip fi ad
add address=111.221.74.0/24 comment=disable_skype disabled=no list=skype_servers_z
add address=111.221.77.0/24 comment=disable_skype disabled=no list=skype_servers_z
add address=157.55.130.0/24 comment=disable_skype disabled=no list=skype_servers_z
add address=157.55.235.0/24 comment=disable_skype disabled=no list=skype_servers_z
add address=157.55.56.0/24 comment=disable_skype disabled=no list=skype_servers_z
add address=157.56.52.0/24 comment=disable_skype disabled=no list=skype_servers_z
add address=194.165.188.0/24 comment=disable_skype disabled=no list=skype_servers_z
add address=195.46.253.0/24 comment=disable_skype disabled=no list=skype_servers_z
add address=213.199.179.0/24 comment=disable_skype disabled=no list=skype_servers_z
add address=63.245.217.0/24 comment=disable_skype disabled=no list=skype_servers_z
add address=64.4.23.0/24 comment=disable_skype disabled=no list=skype_servers_z
add address=65.55.223.0/24 comment=disable_skype disabled=no list=skype_servers_z
add action=drop chain=forward disabled=no dst-address-list=skype_servers_z
Read this too.
http://aacable.wordpress.com/2013/12/09/possible-workaround-for-blocking-skype-with-mikrotik/
I hope this may be useful for others.
After applying many methods to block skype across all my sites so of which block others useful sites. I have found this method to be useful and working fine for me.
Firstly make sure your box is running the latest firmware version of RouterOS.
and use the codes below L7 blocking.
add the L7 regexp
/ip firewall layer7-protocol
add comment=“Drop all through” name=“Block Skype” regexp=
“^.+(skype|skype.com).*\$”
Now apply the firewall filter rule to activate the block.
add action=drop chain=forward comment=“Block Skype” layer7-protocol=
“Block Skype” log-prefix=“Block Skype” time=7h-19h,mon,tue,wed,thu,fri
I am blocking Skype on our networks from 7AM to 1900hr PM monday to friday.
Kindly let me know if this work well for you.
