Block Some Multicast IPs
Hello
I have Multicast IPs on One Bridge ether1 and ether3 and ether2, 244.X.X.X.X the original stream , and 239.X.X.X the transcoded stream , the out put in same bridge ether2 , I need to block 244 from ether2.
my problem because the transcoder use same Ethernet as IP in and IP out I need to block on ether 2 the input original its 100Mb and the output its 35Mb and ether2 only have 50Mb , now I see both 244,239 on ether2 with 135Mb.
Regards
