block some users in specified interface?
hi
how can i block some users to access internet on specified interface? ( hotspot )
for example, there are two users “john” and “tom”. i want both of them could be use internet in interface number 1 and 2 but not 3 and 4.
tank you.
What do you mean? using internet from specific Ether and Hotspot?
Home many Hotspot sever do you have?
i have just one hotspot server.
and 10 Ether.
all i want is one of my users could use internet on just one or two Ether.
All you need to do is to give hotspot account to those one who will use internet. Rest shouldn’t have Username and Password so that they can’t use internet, so simple!
there are two department, Ether 1 is for A department and Ether 2 is for B Department.
i want when a user from A department come to B department couldn’t use internet by login in hotspot.
thats it!
OK.
If you’re not using Usermanager to manage your users:
make 2 Hotspot server, when you want to make new user just set your server:
if you’re using UM, just make limitation:
tanks
