Block subnets accessing each other in mikrotik
Hello ,
I have two subnets in my mikrotik router: Network 1 : 192.168.1.0/24 and Network 2:192.168.5.0/24
I want to allow Network1 to access Network2 , but to deny Network2 access Network1 !!!
By using the rule : /ip firewall filter chain=prerouting src-address=192.168.5.0/24 dst-address=192.168.1.0/24 action=drop
It blocks two networks accessing each-other.
Is there any solution that allows one network to access another one but denies the second one to access the first network ???
Thank you!
Yes, first allow established and related connections, then allow access from Network1 to Network2 and block the rest. Simplified example:
add chain=forward connection-state=established,related
add chain=forward src-address=192.168.1.0/24 dst-address=192.168.5.0/24
add chain=forward action=drop
First rule makes the difference. If allowed connection is established from Network1 to Network2, connection-state=established,related makes sure that all reply packets from Network2 to Network1 are also allowed, while new connections from Network2 to Network1 are still blocked.
good idea from Sob
Thank you very much Sob.
I solved it!!!
Best! :smiley:
