Is there a way to totally block torrent using the mentioned router OS version.
If not, can we apply download limit for torrent traffic only.
Many thanks,
Gerry
Many thanks,
Gerry
You could go quite aggressive :
ā Deny any inbound traffic not part of client-initiated sessions. (but with exceptions that are applicable for your environment, like dns,ntp,smtp,ā¦) and if you host external public services etc.
ā Only allow 80 & 443 outbound (and offcourse DNS,NTP,SMTP etc)
It is not so easy to get this under control by only looking at port-numbers etc.
You should first make an good analysis of what normally your traffic-flows contain. Depending on the size of your environment this can vary from simple to very complex.
