Block Traffic between Interfaces / Subnets
We are setting up a new Mikrotik router with multiple interfaces active on separate networks. We are relatively new to RouterOS, but not to routers and firewalls in general.
From the default RouterOS image we enabled a separate subnet on Eth3. Our interfaces were configured as follows.
Eth1 - DHCP WAN connection
Eth2 - Default IP & Subnet 192.168.88.1 (192.168.88.0/24)
Eth3 - 192.168.16.1 (192.168.16.0/24)
We attempted to install DHCP on a Windows server connected to 192.168.16.0/24, but the installation failed, as it detected the default Mikrotik DHCP server on the 192.168.88.0/24 subnet.
The logical fix is to create a firewall rule on the router dropping traffic between the subnets, so within the Mikrotik web interface we created a firewall rule to block traffic from 192.168.16.0/24 → 192.168.88.0/24 and a second rule dropping traffic from 192.168.88.0/24 → 192.168.16.0/24.
We also tried the same form a telnet session using the following commands.
ip firewall filter add chain=forward src-address=192.168.88.0/24 dst-address=192.168.16.0/24 action=drop
ip firewall filter add chain=forward src-address=192.168.16.0/24 dst-address=192.168.88.0/24 action=dropNeither method worked. We were still able to ping between networks and the DHCP server was still being detected by the windows server.
Any ideas of where we have gone wrong?
maybe ether3 is slave from ether2 or ether3 bridged to ether2
Could you post a configuration dump? How did you add this additional subnet (console, webfig, winbox)? RouterOS will run DHCP only on the interface you tell it to. Usually the default bridge. Like the previous poster indicated it’s possible you did not remove the port from the Ethernet switch or didn’t VLAN it off correctly.
At the very least we’d need a “/interface export” and an “/ip dhcp-server export”
Kangarie is right. This is almost certainly the case if you started from a default configuration. Check the /interface ethernet menu and make sure that ether3 has master=none
The other place to double-check is that ether3 is not part of any bridge (unless you need to bridge a few interfaces for this extra network, in which case your IP-related configs such as addresses, dhcp, and firewall rules need to be on the bridge interface and not directly on ether3)
