Here is a config that is working for me, tested on rb750gr3, rb3011UiAS, rb951g-2hnd. I can not remember from where i have implemented it, most likely from this forum or an outside link from a post.
It stops .torrent file download from browser as well as seeding or downloading inside torrent client (uTorrent, Vuze etc ).
1. define layer7 bit torrent regex table
/ip firewall layer7-protocol
add comment="Block Bit Torrent - tabela regex" name=layer7-bittorrent-exp regexp=\
"^(\\x13bittorrent protocol|azver\\x01\$|get /scrape\\\?info_hash=get /announce\\\?info_hash=|get /client/bitcomet/|GET /data\\\?fid=)|d1:ad2:id20:|\\x08'7P\\)[RP]"
2. add “ofender” ip to a list with timeout set to 5 minutes
add action=add-src-to-address-list address-list=Torrent-Conn address-list-timeout=5m chain=forward comment="Block torrent trafic" layer7-protocol=layer7-bittorrent-exp \
log-prefix=torr-conn src-address={lan_network_range} src-address-list=!allow-bit
add action=add-src-to-address-list address-list=Torrent-Conn address-list-timeout=5m chain=forward comment="Block p2p" log-prefix=torr-conn p2p=all-p2p src-address={lan_network_range} \
where src-address={lan_network_range} is local lan network range ( Ex.: 192.168.0.0/24 )
You can see blocked ips running command:
/ip firewall address-list print
3. drop traffic for non-standard ports ( some of them ) for ips inside Torrent-Conn list ( see 2. )
add action=drop chain=forward dst-port=!0-1024,3389,5222,5800,5900,8291,14147,59905 protocol=tcp \
src-address-list=Torrent-Conn
add action=drop chain=forward dst-port=!0-1024,3389,5222,5800,5900,8291,14147,59905 protocol=udp \
add action=drop chain=forward out-interface={local-lan-interface} content="\r\nContent-Type: application/x-bittorrent" protocol=tcp src-port=80 comment=".torrent \r\nContent-Type...."
where out-interface={local-lan-interface} might be: ether2 or bridge1. For example, if on rb951g-2hnd you have ether2(master) and wlan as ports inside a bridge, named bridge1, then out-interface is bridge1
4. mark torrent traffic packets
/ip firewall mangle
add action=mark-packet chain=postrouting comment="p2p download" disabled=no layer7-protocol=layer7-bittorrent-exp new-packet-mark="p2p download" passthrough=no
5. drop torrent traffic
add action=drop chain=forward disabled=no p2p=all-p2p
add action=drop chain=forward in-interface={WAN_interface} comment="torrent dht out magnet" content=d1:ad2:ad20 disabled=no dst-port=1025-65535 packet-size=95-190 protocol=udp
add action=drop chain=forward in-interface={WAN_interface} comment=info_hash content=info_hash disabled=no dst-port=2170,80 protocol=tcp
where in-interface={WAN_interface} is your WAN interface ( Ex.: ether1 or pppoe-out1 )
and
P.S. MOST IMPORTANT: in order to make it work DISABLE fasttrack, if you had enabled it or has left enabled by default configuration! ( https://wiki.mikrotik.com/wiki/Manual:IP/Fasttrack )
Hope it helps.
kind regards,
