I want to know if I can blockthe discovery from a specific address in my netwrok
so the router will be 10.0.0.1/24
my netwrok is 10.0.0.0/24
but I will only see the it in winbox from 10.0.0.10-10.0.0.20
all other computers in the network that aren’t this address will not see it
From the sound of it, the easiest fix is to just totally disable neighbor discovery, and then just save the IP address in WinBox.
That way no one can see the MikroTik router via neighbor discovery, only if they know the IP address of the router can they access it, and only if they know it is a MikroTik router will they think of using WinBox.
