Hello there,
I am using FTP, SSH, and Telnet Brute Force filters. I also use some other filters.
Whenever I reboot Mikrotik, all the IPs in the blacklist disappears. Is there a way to keep them permamently until the timeout ?
Hello there,
No,
but you can add it to a blacklist permanently.
If you are interested, I write the code for you for do that.
Thanks for the answer Rextended. I would really appreciate for that. Am I able to write a script when the IP is being blacklisted, it automatically adds the date (the time it gets blacklisted) in comment side and then run another script to check comments to scan string and remove the IPs which are older than 10 days for example?
Well, just as I had thought!
Usually I write the script, but this time I was sure we were doing it alone, I do not know why …
