Hello.
I would like to block the users in my networks from accessing their private blogs in blogspot.com, since it turns out they are most of time spending there, and this angry the boss quite a bit.
Anyway I’ve tried the solution by adding blogspot.com to the address list, and then drop the traffic from it, but still - the subdomains are working.
IP addresses can change. It is a nice way to keep chasing your tail …
Something like PI Hole or alternative capable of blocking DNS names seems to be the most practical solution.
VPN will not prevent this either. Then that also needs to be blocked ?
I read layer 7 filtering can be indeed quite performance hungry.
Wild question …
Would PiHole running in a docker container on ROS 7.1rc4 be less of a performance hit ?
I have it as a docker container on a Synology NAS. It has not too much processor impact, from what I can see.
Well, keep it running on your NAS ?
This is how I run it over here, Pihole on my 918+ NAS and running fine for years now.
DNS-traffic on the Mikrotik is intercepted and delivered to the Pihole in case some client has some hardcoded IP’s (eg. notoriously Google) and wants to resolve directly…
RB5009UG+S+IN with a Pihole-Container is a very nice Solution!!
Especially for SME’s who don’t have Servers and low requirements
like for exemple Restaurants, hairdressers, bakery’s ,shrink-Office, Kindergarten , etc..
A bit off topic,
but as soon as i get my 5009, i want to try and run a small 3CX-Server.
It would be an amazing solution to replace AVM Fritz.Box or other All-in-One Routers
Your Firewall is very simple and only as 3 filtering categories.
Internet -> Router (Input)
Internet -> LAN (Forward)
LAN -> Internet (Forward)
Step 1: L7-Filtering (identifying Servers)
The best way usually to implement the L7-Filtering is in LAN -> Internet
In your Case it should be rule #13 and #14. (Before "BLOCK FACEBOOK")
Step 2: Blocking Traffic from blogspot
You can Filter, aka Drop the blogspot Connection between "LAN -> Internet" or "Internet -> LAN" (or theoretically both)
Most people Block via the "Internet -> LAN" filtering.
If performance is an issus, you may want to look at blocking the Upload insteed ("LAN -> Internet")
Step 3: integrate Block-List
If and only if performance is an issus,
It may help to only have 1 address-List for Facebook, Blogspot , instagram, tik-tok and Co.
And only use 1 Firewall-Rule to Block unwanted Services insteed of 5+
