Blocking DHCP on separate network
i’m using RB333 to interconnect 2 remote LANs in routing mode.
Both LAN have a separate DHCP leasing addresses for their own adress space.
My problem is that clients on LAN1 sometimes do get address from DHCP server on LAN2 and it seems i’m not able to prevent this.
What am I doing wrong?
LAN1
192.168.1.0/24
DHCP server 192.168.1.7
RB333 192.168.1.246
LAN2
192.168.0.0/24
DHCP server 192.168.0.2
RB333 192.168.0.3
You could add a drop rule on the forward chain for ports 67 and 68.
Since they have both their own address space, why not route them instead of bridging them?
First of all thanks for answering.
In fact i’m routing between them (at least that’s what i want to do)
I’ve tried to setup a drop rule but it seems that it’s not working
show us the rule you tried.
If you are routing, then these don’t pass the broadcast domain. Hence, they never go past your router. However, the only way they would be passed is if there is a bridge in place.
I’ve set filter rules on IP-Firewall to drop UDP port 67 and 68 on chain forward.
Since i’ve not installed this unit (but the company who did it seems not so present…) how can i double check if this link has been setup as rounting?
thanks
Well do this;
/interface bridge print
Then see what it says and let us know.
/ip route print will also tell you what is setup
or you two lans are plugged into the same switch : )
Here is the response, you will see a destination 192.168.98.xx because actually there is a rebound on a mountain site, since the 2 offices are not visible, and so there are 4 devices:
[admin@HIPERLINK-STA] > interface bridge print
0 R name="hiperlink-bridge" mtu=1500 arp=enabled
mac-address=00:0C:42:1C:FB:39 protocol-mode=stp priority=0x8000
auto-mac=yes admin-mac=00:00:00:00:00:00 max-message-age=20s
forward-delay=15s transmit-hold-count=6 ageing-time=5m
[admin@HIPERLINK-STA] > ip route print
DST-ADDRESS PREF-SRC G GATEWAY DISTANCE IN..
0 A S 192.168.0.0/24 r 192.168.98.3 1 hi..
1 ADC 192.168.1.0/24 192.168.1.246 0 hi..
2 ADC 192.168.98.0/24 192.168.98.4 0 hi..
Just to be more clear i try to draw a scheme of our configuration
LAN1<->RB333-1 <-------------> RB333-2<->RB333-3<-------->RB333-4<->LAN2
RB333-2 and RB333-3 are physically in the same site and they are bridged.
RB333-1 and RB333-4 are located in the LANs premises and they are expected to act as routers.
So basically RB333-2 and RB333-3 are trasparent
Confirm that all four RBs on at the same physical premises?
I’m not sure why you need 2 and 3? If they’re at the same LAN, why not just connect them up on the switch?
I’m sure I’m missing something. But as you’ve mentioned the bridge, that’s where the DHCP broadcasts are slipping across. As Dennis says, rather route then.
