how can I block flash animation with MT firewall? I’m using RB1000 with 3.30 ROS version.
I tried to find regexp for flash to make the layer7 rule…
Any suggestion?
mIRO
Any suggestion?
mIRO
if you use transparent proxy, then you can block by extension (swf)
I’m using NAT, proxy…
well, if you are using proxy, add a rule like this:
/ip proxy access path=*.swf action=deny
and no flash stuff will work
