Hello guys, I have a strange issue in my MT fw.
I have one rule in INPUT a one rule in forward but they are no working properly.
First input rule is the client from internet should be connect to the server behind GW (MT) except defined hours.
1 ;;; Block PC client Heneken BA
chain=input action=drop connection-state=“” connection-nat-state=dstnat
src-address=176.10.43.91 time=19h-8h,sun,mon,tue,wed,thu,fri,sat log=no
log-prefix=“”
The result is drop is not working…I think because client had established connection before 19:00 or because fastrack is active(?)
2nd issue is similar.
My son has active internet in my home gw only from 9-12 a.m. If he try make new connection after 12:00 drop is working properly. If he has connection to the server established before between 9-12:00 drop is inactive and e.g. he can continue playing game after 12:00…he is clever, he found hole in my firewall;o). Have I specify rule for established connections?
11 I ;;; Povolenie netu nb
;;; inactive time
chain=forward action=accept src-address=10.100.10.90
time=9h-12h,sun,mon,tue,wed,thu,fri,sat log=no log-prefix=“”16 chain=forward action=drop src-address=10.100.10.90
dst-address=!10.100.0.0/16 log=no log-prefix=“”
Can you update my firewall rules properly?
I have ROS 6.46.6 in the both cases.
