Blocking IP Backbone While Using DHCP
My network topology is like the picture below. My office has many building and therefore I have setup a backbone network and small network. The backbone network are all connected to the gateway (main mikrotik), user manager, servers, and the local mikrotik in each buildings using IP 10.10.10.x/22. And for each building, I have setup several access points using IP generated from DHCP server in each local mikrotik. I wanna make sure that each user that’s connected through local mikrotik can’t use Backbone IP. Unfortunately, some users can and even if they change it to backbone IP, they still can login to hotspot and internet.
I need your advice. Thank you.
