Blocking Sites
Can any one tell me how to block sites in mikrotik 3.28V.
Thanks,
Srinivas
http://wiki.mikrotik.com/wiki/How_to_Block_Websites_%26_Stop_Downloading_Using_Proxy
I have tried doing this but after configuring i’m not able to browse any site. Is there any other procedure to block sites or can any one help me in doing this.
Thanks Srinivas
That procedure works, so you implemented it wrong.
Post the configuration you applied.
I have tried this and it’s working, can you please tell me how to block a particular subnet.
Thanks,
Srinivas
Add additional parameters to the firewall NAT redirect rule that specify a src-address equal to the client subnet to filtet. If there are several it is easiest to make a firewall address list with all the subnets and use src-address-list instead
