blocking some websites how to
i am using hotspot
how to block smoe websites from being opend ???
also how to loog all webpages opend by users if possible i can make that work with proxy
but how with hotspot ?
first, find out what ip address (the website that you want to blok), using “TORCH”, and put ip on firewall filter, drop forward action for this ip address. :smiley:
Use the hotspot with webproxy, first enable the proxy and after in the NAT section put the next rule to redirect all TCP Traffic from port 80 to 8080 “webproxy”
/ ip firewall nat
add chain=dstnat protocol=tcp dst-port=80 action=redirect to-port=8080
Something very import is select the option TRANSPARENT PROXY into the user profile hotspot. Finally add the rule to block the website into the webproxy section.
