Blocking specific site (porn)!
how can I block porn sites of my users, block URLs with specific words,
thanks alot
Ghaith
use webproxy, and then use access list.
or just use firewall and block the destination IPs if they are known.
using webproxy means that I have to enable caching which makes downloading much slower!
what’s the config for firewall setting? can you please show me?
thanks again
Most people think the opposite about caching …
/ip firewall filter add chain=forward dst-address=159.148.60.20/32 protocol=tcp action=drop
normis,
I appreciate your advice and guidance, are you using the cache feature on your mk server? do you think that I should start using it?
thanks,
Ghaith
many people use it, including us here in the office. it does not cause problems for downloading, it actually improves download speed if many users want to download the same files.
I saw all the Information, but none seems to work for me. :confused:
Pls I will appreciate if there is a way to have those porn site blocked out, someone should please
give me the Idea I mean the command syntax
:frowning:
Set up proxy:
[admin@MikroTik] ip proxy> set enabled=yes
http://www.mikrotik.com/testdocs/ros/2.9/ip/proxy.php
Set up access list:
/ip proxy access
http://www.mikrotik.com/testdocs/ros/2.9/ip/proxy_content.php#7.60.3
I need blocking many words, but in new version of the proxy ( 3.0rc13 ) not equal a version ( 2.9x )
Example:
in version 2.9x = add dest-host= sexy playboy tits action=deny ( many words in one line )
in version 3.x = not is possible, no block !!
Help-me, i need various expressions in one line !!
example : add dst-hot=sexo/ nudez/ tits/ action=deny
ive had very good experience using OpenDNS for porn filtering, it just works. Theres no way you will be able to keep up a list of keywords to filter, and its a lot of load for your router to do it.
with OpenDNS, free by the way, you just use their DNS servers, and register your IP, then you can control how much or little porn, smut, and grubby stuff you want to allow or deny. Very nice, did I mention its free?
jon (not affiliated in any way, just a happy user)
http://www.opendns.com
yes, using opendns as your networks DNS server is a much better solution than guessing all the dirty words people will want to look up in the internet.
I have sucess, this is a example for blocking many words in a one line:
/ip proxy acess add src-adress=0.0.0.0/0 dst-host=:sex|nude|porn action=deny
There was a presentation on this in the Egypt MUM, see this file:
pr0n.doc (72.5 KB)
Although still I say that there are easier ways to do this.
Normis, this example not running in proxy of mikrotik version 3.0 only in version 2.9, i have tested !!
Sandro
I have tried the command as indicated but I am getting invalid preceding regular expression
Please Indicate command precisely.
I am using RouterOS 2.9.50
/ip proxy access add dst-host=:sex|nude|porn action=deny comment=“Block Porn Sites”
Sandro/TGANET
/ip proxy access add src-adress=0.0.0.0/0 dst-host=:nude|porn|hardcore action=deny comment=“Bloack Porn Sites”
This is a corret example !!
Sandro
for me, the easiest way is to enable the web proxy and parent the web proxy to another linux box (ipcop + urlfilter). try searching on google on these keywords.
but you need to add another computer as your proxy parent..
as users request this, you add their IP to your address list for blocked porn sites
Add rule to redirect all DNS UDP 53 queries from that src address list to point to:
67.138.54.100
207.225.209.66
This is a service ,free, called scrubit. Free DNS scrubbing. Works quite well. Most of the time that is. will prevent most of the stuff from getting in. There is a application that you can add to your browser to tell them to check a website to be scrubbed, and they will if it is a porn site.
I do this now, no load on your routers for the most part, 3rd party community supported site and such. so…
hi i’ve tried it..
it works..
but when i doing tranparent proxy to my client, it didn’t work…
i’m using mikrotik V.3rc13 as my parent proxy..
do i have to make the same rule as above?
ps : i also have clients that have priveledges to see that websites, under the same parent proxy..
