and i idea to block or limit torrent in 6.27??
I Use this in layer 7 protocol to identify Torrent then block rule in firewall forward chain.
/ip firewall layer7-protocol
add name=bittorrent regexp=ā^(\x13bittorrent protocol|azver\x01$|get /scrape
\?info_hash=get /announce\?info_hash=|get /client/bitcomet/|GET /data\
?fid=)|d1:ad2:id20:|\x08ā7P\)[RP]ā
not works
What torrent program are you using?
i am using utorrent and yes i want block almost any torrent and the link you give me the code is error because there is no thing like /ip ff in mikrotik
please give me export code from your router and dont forget i am using 6.27 v
and if you have windows update block code please give it to me too.
:IP/Firewall/Filter
I didnāt work with āP2Pā section. But maybe If you Drop all P2P, that should work, I donāt know.
But Itās about a year Iām using Leach services. Itās funny. slow torrents become fast TCP 80 download ![]()
This is user ohara ip firewall rules poasted in the other thread.
These rules block new torrents not the ones u already have started.
add action=drop chain=forward comment=āTORRENT No 1: Classic non security torrentā disabled=no p2p=all-p2p
add action=drop chain=forward comment=āTORRENT No 2: block outgoing DHTā content=d1:ad2:id20: disabled=no dst-port=1025-65535 packet-size=95-190 protocol=udp
add action=drop chain=forward comment=āTORRENT No 3: block outgoing TCP announceā content=āinfo_hash=ā disabled=no dst-port=2710,80 protocol=tcp
add action=drop chain=forward comment=āTORRENT No 4: prohibits download .torrent files. " content=ā\r\nContent-Type: application/x-bittorrent" disabled=no protocol=tcp src-port=80
add action=drop chain=forward comment=āTORRENT No 5: 6771 block Local Broadcastā content=ā\r\nInfohash:ā disabled=no dst-port=6771 protocol=udp
thanks alot my friendā¦
it now works2
Can anyone help with rules for v6.30.2 with NAT and fasttrack?
