I want to set up a ‘boilerplate’ (template) config file that I can use as a base for configuring new units.
I have saved off the config from the first unit to my PC.
I edited the file to remove the mac addresses from the interface config lines.
I copied the template to the new unit
I ‘imported’ the config from / & got ‘script loaded successfully’
BUT
the config is not right - The unit has NO ip address, winbox finds it on a MAC search but if the IP is 0.0.0.0 then it seems you can’t connect to it even via mac winbox…
the units are running v4.9… but they are RB750 units so I don’t have the option of a serial connection to find out what is wrong, the only way back is to default it & try again…
Just curious what is your config? Does it contain all output?
Perhaps it is better to make custom export, which will contain only specific configuration fields.
Config file is simple RouterOS console commands, which set configuration, so you need to make sure all variables are matching.
like /ip address add address=1.1.1.1/24 interface=ether3,
if there will be no ether3, configuration will not be imported further.
Well to make the config I went to the top level (/) on the terminal window & typed export so it should contain all config.
I assumed the order in the output would be the ‘correct’ order to enter the config commands but that may not be the case I suppose!
Interestingly when I pasted the config back in on the terminal it all went through OK - although I had duplicated config (Eg log targets were repeated) - so it may be a sequencing problem for the original export…
Anyway I went back to doing a ‘backup’ & restoring that onto the other devices and it seems to have worked OK and avoids the duplicates as it replaces the default config rather than adding to it.
Mac winbox does seem to work - don’t know why it didn’t earlier -maybe I didn’t wait quite long enough for the ROS to startup!
I have done the 4 boxes now but if I do it again I think I will use the backup file & then write a short script to do the changes on each box - I would rather edit a script than remember which bits of the gui to go through!
The restoration procedure assumes the cofiguration is restored on the same router, where the backup file was originally created, so it will create partially broken configuration if the hardware has been changed.
It’s not recommended by the manual to restore a backup to different hardware.
I’ve not had any issues at all importing configuration files, but our template is not just taken from a ‘/export’ run but was put together manually in the following order:
static admin users
interfaces
IP addresses
routing
DHCP (pools, servers, then networks)
DNS
NTP
firewall filters
firewall mangle
firewall NAT
Hotspot
RADIUS
reconfigure Hotspot for RADIUS
queues
Then all Hotspot directories are deleted and replaced with the default files we use, then SSL certificates are uploaded and imported. Then a last little script is run that reconfigures the Hotspots for SSL.
There’s no specific reason for that order, it’s just how the config grew - but it works just fine in that order for us.
Well I would expect to at least be able to restore a backup onto the same model of router - otherwise the backup is not a lot of use.. “Oh my box has blown up oh & by the way the backup is useless as well…”.
Especially as it is a binary file so you can’t even ‘read’ it to get the config details out of it…
You should always make three files - export, backup and supout.rif to be sure you have all config.
export should be only restored after editing out things you don’t need. on this forum somebody posted an excellent tool to read and compare export files.
