I recently got 2 RB450’s as edge routers for a small web farm installation. Each router has 1 external interface and the 4 remaining ports are setup as 2 different internal networks. of 2 bonds of 2 ports each.
Whilst testing vrrp failover yesterday (which seems very fragile, but another post for those issues!) I noticed that when pulling the cables on the bonded NIC’s the bond remained active and running. Strangely, when 1 cable was pulled this sometimes triggered a vrrp failover (but not always) even though the bond status was running.
The RB450’s are running v5.18
Here’s the bonding information
/interface bonding print
0 R name="bond-a" mtu=1500 mac-address=00:0C:42:BD:19:39 arp=enabled
slaves=a-e4,a-e5 mode=balance-alb primary=none link-monitoring=mii-type1
arp-interval=100ms arp-ip-targets="" mii-interval=100ms down-delay=0ms
up-delay=0ms lacp-rate=30secs transmit-hash-policy=layer-2
1 R name="bond-b" mtu=1500 mac-address=00:0C:42:BD:19:36 arp=enabled
slaves=b-e2,b-e3 mode=balance-alb primary=none link-monitoring=mii-type1
Here’s what the interfaces show when the cables are pulled from one of the bonds
/interface print
# NAME TYPE MTU L2MTU MAX-L2MTU
0 R interweb-e1 ether 1500 1526 1526
1 a-e2 ether 1500 1522 1522
2 a-e3 ether 1500 1522 1522
3 R b-e4 ether 1500 1522 1522
4 R b-e5 ether 1500 1522 1522
5 R bond-b bonding 1500
6 R bond-a bonding 1500
7 vrrp-interweb vrrp 1500
8 vrrp-a vrrp 1500
9 vrrp-b vrrp 1500
interface 6 (bond-a) should not be running!!
Just in case the RB450 won’t work with mii-type1 link monitoring I’ll try type2. Any other suggestions for why the bond stays running even when all the slaves have been pulled? Also, why does pulling 1 slave or reconnecting it trigger a vrrp failover. The up-delay and down-delay are set to 0 (default). Have I made some configuration error elsewhere?
Thanks,
Matt
