Bonded Interface won't pass VLAN Traffic
So I have an odd situation, and I thought I had the settings correct, but it seems that I do not.
Backstory:
I’ve currently got a dell switch, passing traffic to a CRS326-24s+2Q+. I set up SFP+1 and SFP+2 bonded. Said bonded interface is part of a bridge. I am able to pass untagged traffic on the management VLAN, correctly to tagged and untagged ports.
This switch then uses bonded interfaces to talk to another switch in a remote cabinet. Again, I’ve bonded the interfaces (This time it was SFP+21 through SFP+24) to remote switch (SFP+1 through SFP+4). The vlan for that switch comes in the primary bond on switch 1 as tagged, and is supposed to be passing the traffic untagged down to the remote cabinet bond, where the remote cabinet bond is also on it’s own bridge with that vlan as untagged, but it’s not passing traffic.
When I remove the ports from the bond, and set just one interface up on the bridge with the correct vlan untagged, it passes traffic through to the second switch. So I’m at a loss as to why the lag won’t pass the vlan untagged, but the individual port will. Below is a modified export of the two devices.
Below is the skimmed down part of the configs pertinent.
Bond is 802.3ad - mii monitoring with layer 2 transmit hash. 0 min link, 0 down delay, 0 up delay, lacp rate 30s, and mii interval 100ms.
CRS326-1
add name=GPON pvid=2000 vlan-filtering=yes
set [ find default-name=sfp-sfpplus1 ] l2mtu=1592
set [ find default-name=sfp-sfpplus2 ] l2mtu=1592
set [ find default-name=sfp-sfpplus20 ] comment=UPS l2mtu=1592
/interface bonding
add arp-ip-targets=10.100.1.1 mode=802.3ad name=CRS326-1-MTBond1-LAG slaves=
sfp-sfpplus1,sfp-sfpplus2
add mode=802.3ad name=CRS326-1-MTBond2 slaves=
sfp-sfpplus21,sfp-sfpplus22,sfp-sfpplus23,sfp-sfpplus24
add bridge=GPON comment=“Feed to Dell Switch (SFP+1 & SFP+2)” interface=
CRS326-1-MTBond1-LAG pvid=2000
add bridge=GPON comment=UPS interface=sfp-sfpplus20 pvid=2000
add bridge=GPON interface=CRS326-1-MTBond2 pvid=2100
set discover-interface-list=all
/ip settings
set max-neighbor-entries=8192
/ipv6 settings
/interface bridge vlan
add bridge=GPON tagged=
CRS326-1-MTBond1-LAG,sfp-sfpplus4,sfp-sfpplus5 vlan-ids=2010
CRS326-1-MTBond1-LAG,sfp-sfpplus4,sfp-sfpplus5 vlan-ids=2011
CRS326-1-MTBond2 untagged=sfp-sfpplus17,CRS326-1-MTBond1-LAG vlan-ids=2000
add bridge=GPON tagged=CRS326-1-MTBond1-LAG,sfp-sfpplus3 vlan-ids=31
add bridge=GPON tagged=CRS326-1-MTBond1-LAG,sfp-sfpplus3 vlan-ids=47
add bridge=GPON tagged=CRS326-1-MTBond1-LAG,sfp-sfpplus3 vlan-ids=100
add bridge=GPON tagged=CRS326-1-MTBond1-LAG,sfp-sfpplus3 vlan-ids=101
add bridge=GPON tagged=CRS326-1-MTBond1-LAG,sfp-sfpplus3 vlan-ids=636
CRS326-1-MTBond1-LAG,sfp-sfpplus4,sfp-sfpplus5 vlan-ids=2015
CRS326-1-MTBond1-LAG,CRS326-1-MTBond2 vlan-ids=2110
CRS326-1-MTBond1-LAG,CRS326-1-MTBond2 vlan-ids=2111
CRS326-1-MTBond1-LAG,CRS326-1-MTBond2 vlan-ids=2115
add bridge=GPON tagged=CRS326-1-MTBond1-LAG untagged=
CRS326-1-MTBond2,sfp-sfpplus21 vlan-ids=2100
CRS326-2 (Remote)
add name=GPON pvid=2100 vlan-filtering=yes
set [ find default-name=sfp-sfpplus1 ] comment=
“Bond Link to CRS326-1”
set [ find default-name=sfp-sfpplus2 ] comment=
set [ find default-name=sfp-sfpplus3 ] comment=
set [ find default-name=sfp-sfpplus4 ] comment=
set [ find default-name=sfp-sfpplus9 ] comment=UPS
/interface bonding
add disabled=yes mode=802.3ad name=CRS326-2-MTBond1 slaves=
sfp-sfpplus1,sfp-sfpplus2,sfp-sfpplus3,sfp-sfpplus4
add bridge=GPON comment=“Uplink from CRS326-1”
interface=CRS326-2-MTBond1 pvid=2100
add bridge=GPON comment=UPS interface=sfp-sfpplus9 pvid=2100
sfp-sfpplus15,sfp-sfpplus16,sfp-sfpplus17,sfp-sfpplus18,CRS326-2-MTBond1
vlan-ids=2110
vlan-ids=2111
add bridge=GPON untagged=CRS326-2-MTBond1,sfp-sfpplus9 vlan-ids=2100
vlan-ids=2115
