Hello
I have 2 radio jumps where I want redundancy and more bandwidth.
The jumps are no like this:
A ↔ B B ↔ C
There is one radio link between A and B, and one link between B and C.
And the capacity is used in point B and C
I now plan to set up another parallel link between A and B, and a parallel link between B and C.
Any way to set up RB 693AH or RB 750G in point A, B and C to increase bandwidth and give redundancy?
What type of configuration would you recommend?
You will need 2 radios at a and c and 4 radios at b both RB should handle what you what to do.
Here is a basic how to.
http://wiki.mikrotik.com/wiki/Dual_Setup_with_OSPF
Thank you for quick reply.
I will set up extra radios, so that is ok.
I forgot to mention that I have mainly a L2 network setup with VLANs etc.
Will this OSPF setup work for this scenario?
Since you control both routers you can try playing around with bonding as well:
http://wiki.mikrotik.com/wiki/Manual:Interface/Bonding
That should help you keep layer 2 functioning as well.
