I work for an ISP. We are currently using a Cisco 3725 router to bond 5x-6Mbps ADSL lines using MLPPP as a wireless backhaul. We are not able to get the full 30Mbps so we are looking for other solutions. Does anyone have recommendations on what hardware will do the trick?
I havent tried bonding for quite a few MT releases but I never found the speed to be exactly what you would expect. In the country where I live ADSL is quite heavily contented and bonding lines isnt always up to much because the contention at the exchange or higher in the network takes away the benefits.
You can try looking at this old post from ChangeIP.
I used something similar in a few locations and it works well for bonding DSL lines, provided of course the lines are not too heavily contended.
The bonding scenario was developed with ROS 2.9 but should only require slight modifications under ROS 5.xx
http://forum.mikrotik.com/t/multiple-wan-default-gateway-strangeness/12277/1
Deleted because not related.
you should use MLPPP client in RouterOS to connect, if that is in fact MLPPP
http://wiki.mikrotik.com/wiki/Manual:MLPPP_over_single_and_multiple_links
