Bonding between two ADLS Lines.
Hi..
I am trying to setup bonding with EoIP tunnels between two ADSL Lines.
First ADSL Line (2mb) connected to ether1
ether1 address=192.168.1.50/24
ADLS Modem ip=192.168.1.1/24
Second ADSL Line (2mb) connected to ether3
ether1 address=192.168.2.50/24
ADLS Modem ip=192.168.2.1/24
ether2 connected to local network
ether2 address=172.16.10.1/18
Now i want to create an EoIP tunnel so that i can get maximum throughput, but i am unable to set it up.
Please provide some steps, how to accomplish this task.
Unless you have a Mikrotik or at least a Linux box on the other side of the link it won’t work.
Hi..
Dear JWCN,
Thanks for the information.
Mudasir, there’s also a nice tutorial on the training site for bridging remote networks using EOIP.
Maybe this will help you?
HI..
Can you please direct me to the exact link, it will become much easier for me.
this one? http://wiki.mikrotik.com/wiki/Transparently_Bridge_two_Networks_without_using_WDS_(EoIP)
Nice except that there’s nothing there yet :slight_smile:
I was thinking about this one, by Arnis;
http://training.mikrotik.com/course/category.php?id=2
Bridging Remote Networks at the bottom, but you’ll have to login to access it.
sorry, the link broke off. the article is there, just add one bracket )
http://tinyurl.com/6jbyc3
Thanks normis. I should have looked harder.
Hi…
It is still not the thing that i am looking for. As i said i have ADSL Modems on both ends. So i can not configure them to use EoIP. Is there any other solution.
If I may ask, why not? Just put them in bridge mode and run the pppoe from the routerboard.
Unless I’ve got the cat by the short and curlies.
