Well… another instance of “if it aint broke… don’t fix it.”
I installed V3 on a perfect working RB532 and when it rebooted I lost all connectivity to it.
I had all 3 ports bonded to a switch with 5 vlans, and it’s been running great for over a year.
Now… to get back running, I’ve had to break my bonded ports…
anyone else having this problem?
Know of a fix?
Thanks.
Follow-up:
I downgraded to 2.9.50 … restored my wiring… and BINGO… back up and running… 5 vlans over 3 bonded ports.
Soo… guess it’ll be a while before i “upgrade” to v3.
it won’t get fixed any time soon if you dont post your configs and possibly send a supout to support if its truly something wrong… im guessing its just that the configuration has changed enough for 3.0 that your 2.9 config doesnt work as is.
