Bonding different speed connections
I know that you can bond connections of different speeds but I am pretty sure it is only possible to get them to perform x times the slowest connection. Would it be possible to change the system so that it works like multi path so that you can add a connection twice if it is faster therefore giving a weight to each line?
Tim
