Hi, apologies as I am new to this so please bear with me as I try to explain…
I have 2 ADSL internet connections from the same ISP. I have a block of IP addresses which I can route down both lines.
I have a LAN network behind this on a private IP address range (192.168.16.0/24).
What I would like to achieve is to route all traffic down line A and then failover to line B if line A goes down.
I would also like incoming traffic (i.e. email on port 25) to still come in on line B if line A fails.
I would also rather (and I’m sure it’s possible) bond both lines as if they were 1 line. So as far as the LAN is concerned all outgoing traffic goes over a pseudo interface and doesn’t care which actual line it uses if that makes sense?
I hope someone can help.
