I have a fairly simple bonding setup: two links to my ISP, each of which are plugged into an ethernet port on a RB450G. I have it configured so the fastest link is the primary and the slower one is the backup link. I’m using Arp monitoring, and everything used to work great. I don’t remember what version I was running, but I upgraded to 3.30, and I started noticing that I was losing up to 10% of my pings to anything after the RB450. I simply disabled the ethernet interface for the backup link, and pings are stable again.
Does anyone know if the active-backup mode has been broken in 3.30 or if there is a better way to achieve what I want.
Thanks,
Joe
