Little question about bonfding int. in v2.9 - Is possible to use this function on wifi cards (Prism) ?
/Tomi
/Tomi
if you will make EoIP tunnel between both sides then yes, you can use bonding specifying the names of EoIP interfaces as ‘slaves’ values.
Edgars
