I am working on a test Environment, with MPLS/VPLS configuration between 2xCCR 1036, all ports are set to support L2MTU=1600, and everything is working perfect until I started to add a Bonding interface between the CCR and a Cisco Switch, to Increase capacity, on the Cisco Side all interfaces MTU is set to 1600, and the Etherchannel as well is set to 1600, but on the Bonding interface I can't set the L2MTU = 1600, due to that packets is being fragmented.
any other solution to bridge 2 ethernets with high L2MTU size
will Mirkotik add this feature to the Bonding interface?
NAME TYPE ACTUAL-MTU L2MTU MAX-L2MTU MAC-ADDRESS
16 X bonding1 bond 1500
Regards,
