Hello Everyone,
I’d like to ask how to create trunk interface with tagged traffic over bonding interface?
Bond interface is connected to the server and is working.
When I tag traffic on the server with VLAN 10 is working ok.
When I switch to tag 40 it’s not working.
This is my config:
/interface vlan - to route traffic between vlans
add interface=bridgeLocal name=SERVERS vlan-id=10
add interface=bridgeLocal name=USERS vlan-id=40
/interface bonding
add mode=802.3ad name=bond1 slaves=ether5,ether6,ether7 transmit-hash-policy=\
layer-2-and-3
/interface bridge port - bridge created to server
add bridge=bridgeLocal comment=defconf interface=ether3
add bridge=bridgeLocal comment=defconf interface=ether4
add bridge=bridgeLocal interface=bond1
/interface ethernet switch egress-vlan-tag - trunk to another switch
add tagged-ports=ether1,switch1-cpu vlan-id=10
add tagged-ports=ether1,switch1-cpu vlan-id=20
add ports=ether1,ether3,ether4,switch1-cpu vlan-id=10
add ports="ether1,ether3,ether4,switch1-cpu" vlan-id=20
- Should I add slave interfaces to /interface ethernet switch vlan ?
- Should I create /interface vlan for bonding interface ?
- Should I add slave interfaces to /interface ethernet switch egress-vlan-tag ?
Thanks for help in advance!
