bonding need help
hi all, could any one can help me how to configure bonding with 2 link wireless. i still not success with my configuration:
[admin@MikroTik] interface> pr
Flags: X - disabled, D - dynamic, R - running
NAME TYPE RX-RATE TX-RATE MTU
0 R ether1 ether 0 0 1500
1 R wlan1 wlan 0 0 1500
2 R wlan2 wlan 0 0 1500
3 R wds1 wds 0 0 1500
4 R wds2 wds 0 0 1500
5 R bridge1 bridge 0 0 1500
6 R bridge2 bridge 0 0 1500
7 R eoip-tunnel2 eoip-tunnel 0 0 1500
8 R bonding1 bonding 0 0 1500
9 R eoip-tunnel1 eoip-tunnel 0 0 1500
[admin@MikroTik] interface bonding> pr
0 R name="bonding1" mtu=1500 mac-address=FE:2C:DB:B5:83:4D arp=enabled
slaves=eoip-tunnel1,eoip-tunnel2 mode=balance-rr primary=none
link-monitoring=none arp-interval=100ms mii-interval=100ms
down-delay=0s up-delay=0s lacp-rate=30secs
0 R name="wlan1" mtu=1500 mac-address=00:15:6D:63:29:88 arp=enabled
disable-running-check=no interface-type=Atheros AR5413
radio-name="00156D632988" mode=bridge ssid="ERA" area=""
frequency-mode=superchannel country=no_country_set antenna-gain=0
frequency=2462 band=2.4ghz-b scan-list=default rate-set=default
supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps
supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,
54Mbps
basic-rates-b=1Mbps basic-rates-a/g=6Mbps max-station-count=2007
ack-timeout=dynamic tx-power-mode=default noise-floor-threshold=default
periodic-calibration=default periodic-calibration-interval=60
burst-time=disabled dfs-mode=none antenna-mode=ant-a wds-mode=static
wds-default-bridge=none wds-default-cost=100 wds-cost-range=50-150
wds-ignore-ssid=no update-stats-interval=disabled
default-authentication=yes default-forwarding=yes default-ap-tx-limit=0
default-client-tx-limit=0 proprietary-extensions=post-2.9.25
hide-ssid=no security-profile=default disconnect-timeout=3s
on-fail-retry-time=100ms hw-retries=15 preamble-mode=both
compression=no allow-sharedkey=no
[admin@MikroTik] interface bridge port> pr
Flags: X - disabled, I - inactive, D - dynamic
INTERFACE BRIDGE PRIORITY PATH-COST
0 wlan1 bridge1 128 10
1 wds2 bridge1 128 10
2 wlan2 bridge2 128 10
3 wds1 bridge2 128 10
hello…
is there any body can help me…please
