Hey all,
did anyone manage to get Bonding (mode=balance-alb) to work on the RB1000? I’d like to bond two interfaces on this router for inbound and outbound load balancing and failover, and balance-alb seems ideal in this case.
MT Manual says that the Interface drivers must support MAC address change to use balance-alb, and in fact the MAC address of the RB1000 Ethernet interfaces cannot be changed manually. Does this mean balance-alb is not supported on MT’s highest end board or it’s a bug?
Edit: balance-tlb works fine.
I’m running ROS 3.6.
