Bonding problem
i have 2 UBNT Rocket links in AP WDS/ST WDS. When I test each one i get TCP 70Mbps up/down one way test. I made bonding interface with balance-rr, and with that bonding interface i get 70Mbps one way when i should get like 120-140Mbps. One one side is RB493AH and on second RB450G. I tried 4.11OS and 5.beta6. Is there any incompatibility with equipment?
Try to run bw test on each link at the same time.
Ok. I tested all equipment. Problem is in RB’s. RB493AH - RB493AH bonding 2 eth interfaces bandwith test 55/55M TCP Both. One way 75M TCP. X86 P4 160/160M TCP both and 185M one way(100Mbps ethernets so thats max)
