Hi, in the Linux kernel configuration, the primary_reselect parameter for bonding mode is available. It is possible to set this parameter in RouterOS?
primary_reselect
Specifies the reselection policy for the primary slave. This
affects how the primary slave is chosen to become the active slave
when failure of the active slave or recovery of the primary slave
occurs. This option is designed to prevent flip-flopping between
the primary slave and other slaves. Possible values are:always or 0 (default)
The primary slave becomes the active slave whenever it
comes back up.better or 1
The primary slave becomes the active slave when it comes
back up, if the speed and duplex of the primary slave is
better than the speed and duplex of the current active
slave.failure or 2
The primary slave becomes the active slave only if the
current active slave fails and the primary slave is up.The primary_reselect setting is ignored in two cases:
If no slaves are active, the first slave to recover is
made the active slave.When initially enslaved, the primary slave is always made
the active slave.Changing the primary_reselect policy via sysfs will cause an
immediate selection of the best active slave according to the new
policy. This may or may not result in a change of the active
slave, depending upon the circumstances.
