In a simple connectivity scenario consists of a Wireless AP-bridge and 2 SU’s (10Mb/s bridged WDS-station each) how to configure 2 Mktk routers at both ends in order to simply agregate 2 SU wireless links (bonding1 interface) and get at ~18-19Mb total throughput ?
1st Mktk router is connected to the Access Point (R1 - ether1) and 2 subscribers are connected to the 2nd router (ether1,ether2 - R2).
My idea was to configure a pair of EoIP interfaces at both routers and assigned them to ‘bonding1’ interfaces. Scenario works but with very bad performance - upload test didn’t work at both routers !
Download test is as same as a download through a singe link (~10Mb/s).
Mktk ROS ver. 3.3
Any help or suggestion is wellcome.
Thanks,
D.
