Bonding question
Dears,
Is there other way to make a bonding without eoip-tunnels?
Regards,
Ademir Peixoto
http://wiki.mikrotik.com/wiki/Bonding_Examples shows how to use bonding. While it uses EOIP interfaces for the examples, you can also bond normal ethernet interfaces the same way.
HTH,
Felix
Hello, Thanks.
But I need to bonding wireless interfaces to get more throughput and fail-over.
In station-pseudobridge not work.
Regards,
Ademir Peixoto
