Hello all,
I’ve been having issues trying to build a bond between two interfaces (ether3,ether4) on my CRS109 and my TrueNAS storage server. I come from a Cisco background so if anyone could point me or explain how SwOS/RouterOS handles and manages bonding interfaces I would greatly appreciate it. For example:
Why do the sub-interfaces need to be removed from the bridge?
What exactly does one port being a “master” of another port do and why does that affect bonding interfaces?
Does/How does SwOS/RouterOS handle bonding interfaces differently than Cisco IOS?
Thank you!
tdw
November 21, 2022, 4:23pm
2
It varies depending on the Mikrotik device architecture.
On CSS devices the ports are always part of the bridge. You can either assign two or more ports as a static link aggregation group or use LACP, either active or passive. From the help pages CSS610 use L2 hash https://help.mikrotik.com/docs/display/SWOS/CSS610+series+Manual#CSS610seriesManual-LAG , CSS326 and CRS3xx running SwOS use L2+L3+L4 hash https://help.mikrotik.com/docs/pages/viewpage.action?pageId=76415036#CRS3xxandCSS32624G2S+seriesManual-LAG
On CRS1xx/2xx devices to use hardware supported bonding use /interface ethernet switch trunk not /interface bonding . You assign two or more port members of a bridge as a static link aggregation group, note LACP is not supported. From the help page https://help.mikrotik.com/docs/pages/viewpage.action?pageId=103841836#CRS1xx/2xxseriesswitchesexamples-Trunking they use L2+L3 hash.
On other devices use /interface bonding , note the members of a bond interface should not themselves be added to a parent bridge only the bond interface. The switch chip can hardware offload the bonding if supported, see https://help.mikrotik.com/docs/display/ROS/Bridging+and+Switching#BridgingandSwitching-BridgeHardwareOffloading and https://help.mikrotik.com/docs/display/ROS/CRS3xx%2C+CRS5xx%2C+CCR2116%2C+CCR2216+switch+chip+features#CRS3xx,CRS5xx,CCR2116,CCR2216switchchipfeatures-Bonding , otherwise is handled by the CPU which may limit performance.
So using a CRS109 you should not configure TrueNAS with its default method of LACP , loadbalance would likely be best as roundrobin can lead to out-of-order packet delivery.
Amazing, thank you so much! It may have been I was trying to use “/interface/bonding” the whole time, causing my issues. I’ll try the approach you shared and hopefully be met with better results. Thank you again!
