Bonding (rr) with two radio (wlan1 and wlan2)
Hello!
I own 2 Mikrotik N2458 0.05.
The mainboard has 2 radio modules.
I’m interested in creating a radio link with bonding (rr) for packet aggregation.
This guide http://wiki.mikrotik.com/wiki/Bonding_Examples doesn’t clearly explain how, it doesn’t even mention about wlan1 and wlan2
Do you have any links and/or suggestions on how to do it?
Very thanks
Regards
Wlans are not mentioned there because, EoIP tunnels are running over each wireless link and then those EoIP tunnels are bonded together. Just look at picture it explains everything.
Thanks for reply!
And where I can set freq, ssid, etc.. for radios?
ssid frequency and other wireless settings has nothing to do with bonding. Go to wireless section of the manual and look for answer there.
http://www.mikrotik.com/testdocs/ros/2.9/interface/wireless.php
Is it the corret way…
A:
interface wireless set wlan1 ssid=Radio1 frequency=5805 mode=bridge disabled=no
interface wireless set wlan2 ssid=Radio2 frequency=5855 mode=bridge disabled=no
B:
interface wireless set wlan1 mode=station-wds ssid=Radio1 disabled=no
interface wireless set wlan1 mode=station-wds ssid=Radio2 disabled=no
and after this bonding with precedent guide?
Thanks again
I have tried it without good results :confused:
Can I leave Radio1 and Radio2 without IP address?
For wireless maybe could try this http://wiki.mikrotik.com/wiki/Dual_Setup_with_OSPF or http://wiki.mikrotik.com/wiki/Setup_Dual_Wireless_Link_with_OSPF
