I am one of whose guys with 25 Gbit/s Fiber in Switzerland.
I use a Mikrotik ccr2004-1g-12s+2xs as the Router and directly behind it I have a CRS309 Switch. I also, have another CRS309 in another room. Both CRS309 are connected with each other. The Mikrotik ccr2004-1g-12s+2xs is only connected via an SFP28 Modul to WAN, and via one (two when I tried bonding) cable with the first CRS309 Switch.
So far, my Threadripper Pro System could achieve around 8 Gbit/s via iperf to the WAN via the 10G Ethernet Port. The Router was near 100% with that traffic.
Now I tried bonding via DAC cables between the Router (Mikrotik ccr2004-1g-12s+2xs?) and the Switch (CRS309). I tried 802.3ad (MII Link Monitoring) and balance rr Mode (ARP Monitoring). Both worked. However, it seems that bonding eats so much CPU Power on the Mikrotik ccr2004-1g-12s+2xs that then iperf went even down to 4 Gbit/s (with the Router being at 100% CPU Load).
Is there a trick to reduce CPU load on the Router or does bonding really that useless on it because it even halves the maximum bandwidth?
This CCR2004 has no hardware-switch chip, so all L2-Features have to be CPU-emulated.
It seems this is the best the CPUs can do. In the test-results (https://mikrotik.com/product/ccr2004_1g_12s_2xs#fndtn-testresults), 25 Firewall-Filter-Rules will also decrease the througput to ~4,5GBit.
But as of today, 25GBit is more a joke than really useable. Almost nothing can handle this speed, the network equipment, your “PC”, your storage, the remote server, the WiFi. This speed is beyond the scope of most of the enterprise equipment out there. Even ROSv7 cant Queue this, because there is 2^32 Bit Limit (~4,3GBit). So basically you see simply the border of the “state of the art” as of today. Thats like: Its 1995 and your Win95-Hardware + your half-duplex hub should be able to provide full VDSL-Speed, but everyone around you usese a 56k dial-up connection.
My only “tipp” for you, be happy to have such a decent speed. And for the 25GBit, wait 5 or 10 years until hardware is out, which can handle these speeds. Or buy really high-end quipment, which can handle 25GBit. But thats in the year 2022 not Mikrotik. Look for Cisco, Brocade, Juniper…
I did got a test setup with 7beta doing test between 2 ccr2004-1g-12s with crs317 and mlag and btest were about your speed but router should give a bit more as lot of cpu was used by btest in my setup.
(Note that is not good to measure speed from router as I did. Documentation said: “Bandwidth Test uses a lot of resources. If you want to test real throughput of a router, you should run bandwidth test through the tested router not from or to it”)
Same question as another user… what version of software do you have on the 2004?
I have 7.2.1 on mine and it made a huge difference in performance (compared to 7.1 and 6.47/48/49). That said, I doubt it’ll be able to route much above 10Gbps.
The most I’ve successfully tested through mine is 6Gbps bridged from a 10Gbps port to a 25Gbps port (both using 10Gbps SFP+ modules; 6Gbps bottleneck was the 27km 80GHz uplink to the datacenter).
