Bonding via wireless
Hi
I’am having problem to get bonding to work.
I have set up a 750UP whit two SXT AP pointing at two other SXT Stations that are connected to a 750UP.
All SXTs has bridge configured whit the two interfaces, ether1 and wlan1. The IP are assign to the bridge.
The Bonding is running balance rr in the two 750UP.
The problem is that I can’t ping from 192.168.99.1 to 192.168.99.6.
But in the first 750UP 192.168.99.1 the second 750UP whit 192.168.99.6 shows as neighbor.
Any ideas? where did I go wrong? How should i do it?
Any one?
Try to move the RB750 to a different IP range of the SXT’s.
