BONDING WITH WIRELESS
I have configured bonding between Routers 450G(router 1 and router 2) and everything works fine but when I want to log in to one of the 433AH int the middle it is imposible, does anyone know if there is any chance to monitor those routers?
Put the ip to the bounding interface, and put it in bridge. Then the router should respond.
If you use a routed setup. put the IP to a loopback interface (bridge) with an /32 netmask.
thanks for your answer samsung172, I have ping to all devices but the ping is like this:
10.254.254.25 timeout
10.254.254.25 56 64 9ms
10.254.254.25 56 64 1ms
10.254.254.25 56 64 0ms
And in my Dude I see the device going up and down.
please help me to monitor this devices.
seems like you have a net that is replying like that. How about your wireless links? Are they stable,up and ok?
Yes, the two wireless links are fine. The bonding doesn’t leave me to have a continius ping to the wireless devices.
