Boot problem
Dear All,
I have rb450 router and facing problem of booting. Router boots and 2 beeps come.
but not able to login from www, winbox or telnet or even serial cable.
I also check with serial console cable but when it boot it show symbol but not login prompt.
plz help me out, what can i do know.
On the serial terminal are you using 115K, 8, N, 1?
If you have the wrong settings, you will get symbols instead of alpha numeric messages that you can read.
Tom
Dear Tom
Thanx for Your valuable reply its works for me.
Thanx
