Hello! My eth1 port has stopped working, only PoE works at the moment. I can access the router from serial connection but I can´t boot it from the eth0.. So, can i change eth port for booting or is it already using every port?
Regards, Mattias N, Sweden
Hi, no on all RB only ether1 support boot over Ethernet. What happen with RouterOS from NAND?
Oh.. That´s to bad.. Nand ?.. Can i install routeros from serial port ?
Regards, Mattias
No, over serial port you can replace only BIOS
